No Sound with component cables
Discussion in 'Nintendo Wii-U & 3DS' started by natoffski, Jan 2, 2007.
  1. natoffski
    natoffski
    Oct 16, 2006
    172
    +6
    Hi guys just got my Official Wii component cables today , anyway i have attached them to my pioneer 43" HD TV and i have a Wii Menu but i have no sound at all ive tried to see if there is an adjustment but there doesnt seen to be, normal tv has sound ans the Wii with standard cables there is sound 2 anyone help
    thanks nat
  2. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,321
    Essex
    +1,016
    i take it you have connected the
    red
    green
    blue
    for video ( as you say you have a picture )
    and have you connected the
    red
    white
    for sound ?
  3. hillster
    hillster
    Feb 11, 2004
    720
    Reading
    +29
    No inputs on the tv for the red and white connections? If not do you have an amp to connect to?
  4. natoffski
    natoffski
    Oct 16, 2006
    172
    +6
    just as it is on the diagram and back of tv, video are 3 together and the red /white on there own for sound nothing ....:thumbsdow
    just rung game in bradford and they said take back and change them as there should be sound straight away
  5. dan653
    dan653
    Mar 26, 2006
    1,287
    48
    nr Stonehenge
    +49
    get the inputs menu up on your tv might need to switch their function on my toshiba 32wlt66 they can be configured for use with the component connectors or the vga connector or in your case maybe an audio output from your tv
    got anything else you can test for sound via component on your tv (dvd player, ps2, gc, xbox, xbox 360)
  6. johnelf
    johnelf
    Nov 10, 2003
    705
    46
    Epsom
    +106
  7. natoffski
    natoffski
    Oct 16, 2006
    172
    +6
    ill have to get the scart thing to try it , i agree with your quote about paying the money to think where getting a better product cos i got the picture with the component cables and to be honest there wasnt much difference when i switched it to HD in the Wii menu
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,356
    2
    4
    137
    Garstang, Lancs
    +1,632
    Were you using RGB before or composite?
  9. natoffski
    natoffski
    Oct 16, 2006
    172
    +6
    I was just using the 3 into the scart that was supplied with the Wii console
    i got a picture thru my new component cable just no sound at all
  10. t-force
    t-force
    May 2, 2001
    1,872
    Southampton, UK
    +152
    This may sound like a stupid question, but the two sockets you've got the sound cables plugged into are definitely inputs, aren't they? I only ask because my TV (admittedly neither a plasma, nor a Pioneer) has two audio sockets, but they're outputs, rather than inputs.
  11. a27
    a27
    Dec 10, 2006
    1,031
    48
    +29
    You're in Bradford?
  12. a27
    a27
    Dec 10, 2006
    1,031
    48
    +29
    I have the same problem.
  13. johnelf
    johnelf
    Nov 10, 2003
    705
    46
    Epsom
    +106
    The Component rgb cables only carry the picture. Listen via amp with optical or use red n white audio jacks. On my Pio 504, I plug red n white Audio into a scart converter and plug this into my tv that way. Then you have audio.
    Good Luck
    John
  14. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    You should have a scart adapter supplied with your Wii, takes audio & composite video.
  15. a27
    a27
    Dec 10, 2006
    1,031
    48
    +29
    Is this normal operation?
    I get sound from connectinig the Playstation 2 to component without scart.
    The red, green and blue component cables are plugged into the component input.
    The red and white sound cables are plugged into the TVs audio in.
  16. lestmak
    lestmak
    Jan 18, 2007
    25
    3
    +3
    check your tv for it's audio input. my philips 26" was a bit of a nightmare in that i needed a converter for component to DVI input, and the audio input was a traditional 3.5mm headphone type socket, so need a phono converter. But all works brilliantly now.
  17. dannius
    dannius
    Feb 12, 2006
    3,402
    +349
    Does anyone else notice much of a difference with the component cable? I switched my wii from standard pic to 480p and to be honest it doesn't look much different.
  18. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    If it all worked fine through a scart socket then that's okay. Video and Audio together.
    When you use the Component inputs on my Panny the Audio has to go in through a scart socket (AV4). Might be the same on the Pioneer.
    So it's like folk have said, use the scart adaptor just for Audio (White and Red only) to the required scart. You might need to change some settings in options.
    Read your manual.
    I suspect the white and red phonos on the rear of the set are indeed outputs.
    Pablo
  19. Looeewoo
    Looeewoo
    May 12, 2006
    477
    Edinburgh
    +34
    Yeah, picture gamma is better - much too bright on composite - and also sharper, better colour saturation.
  20. a27
    a27
    Dec 10, 2006
    1,031
    48
    +29
    Sound is now working without scart.
  21. Decadent Fool
    Decadent Fool
    Dec 27, 2006
    546
    28
    Shropshire
    +33
    Ooooh yes; picture was okay before I upgraded tv and then it sucked; almost too painful to watch !
    Component cables cured that :)
  22. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    specsavers..or a new tv,the 2 are totally different.:rotfl: :rotfl:
  23. steggy
    steggy
    Apr 3, 2006
    738
    28
    +46
    The main improvement with component will happen after you swap the leads over, switching to 480p after that will make some improvement but you may only notice the difference when things are in motion.
    The best way to check the improvement is to swap the cables over, when I got mine I was amazed to see that empty channels showed static on them and didn't just look like a blur.
  24. dannius
    dannius
    Feb 12, 2006
    3,402
    +349
    I think your probably getting the wrong end of the stick with what I asked. I never used composite, went straight to component. What I was saying is that when I choose 480p it doesn't seem much different from the standard pic (using component also) which I assume is 576i?
    Obviously there is a huge difference between composite and component, but I never got the composite cable near my TV!
  25. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    ah..i dont think it does let you select 576i,with the component cables on the uk wii.its just 480p straight off,no matter what you pick.
    i tested it last night,and theres no difference between any of the settings with component.so it must just set,and thats it.
