No sound via optical from a Denon 11SR
Discussion in 'AV Receivers & Amplifiers' started by oreoboy13, Aug 1, 2002.
Tags:
  1. oreoboy13
    oreoboy13
    been working for about 6 months and suddenly i cant get any sound via optical i have tried two different sources with two different optical leads, and nothing. i then tried reassigning OPT ports with no luck, then i tried setting the input to DBS instead of DVD and still nothing. The sources were my TV built in dvd player and a ps2.
    I have yet to try a coax, but i was wondering if anyone had any ideas, experience, suggestions etc?
  2. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    Yeh if it has been working for 6 months then the answer is its broke if you have tried different sources and different interconnects.
    Send it back
  3. Jase
    Jase
    Mar 16, 2001
    10,815
    United Kingdom
    +2,693
    Try resetting the amp, hold down the Stereo & Direct buttons whilst turning the amp on, the display will flash a couple of times.
    Before you do it, make sure you write down all your settings, speaker distances, levels etc.
    If it does´nt work after that, it will need to go back to Denon to be looked at.
  4. oreoboy13
    oreoboy13
    Jase you star, fully working now. Thank you so much, i can now start watching films again :)
