No sound using SPDIF
Discussion in 'Computer Components' started by DrPepper, Jul 28, 2003.
  1. DrPepper
    DrPepper
    Oct 2, 2001
    3,148
    Barking Essex
    +236
    I have a motherboard which has PCI sound adapter for SPDIF out
    Using theatertek 1.5 set to SPDIF going into a Denon 3081
    A co-axial cable used for sound connection .
    I’m not getting any sound out of the Denon?
    Anyone knows were I’m going wrong?
  2. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    Have you tried the Theatertek forum/help guide thing? There is a lot on there about sound problems and drivers etc.
    Have you set spdif in the audio setup section?
    Andy
  3. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Its either the digital out on your soundcard not enabled or the incorrect setting in Theatretek or both.
    Dont forget that when you change a sound setting in Theatretk the program has to be restarted for the change to take effect.
  4. DrPepper
    DrPepper
    Oct 2, 2001
    3,148
    Barking Essex
    +236
    ilkand/JohnS
    Yes spdif is set in the audio setup section.
    Checked the bios the sound card is enabled.
    XP says sound card working properly.
    I tried normal PC speakers using the jacks and I get sound.
    I have also restarted Theatertek for the sound to be set.
    I'll check the Theatertek forum/help
    DP
  5. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Which motherboard are you using?
  6. DrPepper
    DrPepper
    Oct 2, 2001
    3,148
    Barking Essex
    +236
    Gigabyte.
    Don't know which one I need to check when I get home
  7. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    and what sound chipset it uses might be helpfull.
  8. DrPepper
    DrPepper
    Oct 2, 2001
    3,148
    Barking Essex
    +236
    JohnS
    It's a Gigabyte GA-7VAXP motherboard.
    Realtek ALC650 CODEC? sound chipset
  9. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Well I can confirm that the Realtek chipset works with Theatretek as its the same one my brother has in his Asus A7v8X. I do remember it being akward to find the bit that enabled the spdif and that it wasn't in an obvious spot, but unrfortunatly cant point you to the exact location, once you've found it, just methodically work through the Theatretek audio settings untill one works...it will!
  10. DrPepper
    DrPepper
    Oct 2, 2001
    3,148
    Barking Essex
    +236
    I will check all the audio settings.May be down load the last
    drivers.
    JohnS thanks for your help.
  11. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    I've got the same chipset motherboard. Do you get the NForce Control Panel in your system tray? On that I had to go to the Speaker Setup tab and then tick the Digital Output checkbox in that panel...
  12. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Just re-read the post. I've got a different motherboard, I just have the motherboard that was mentioned by JohnS (A7v8X). Soz!
