No sound over optical link
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Stimpy, Oct 24, 2003.
  1. Stimpy
    Stimpy
    Have just got sky+. Have tried to link to my Marantz 500SE AV amp via optical cable. No joy, set to normal or DD.
    Cable works fine to DVD player (older sony 525).
    Is there any specialy compatibility required to sky+ output as my av am is rather old.
    I know the cable works as does the amp (i.e DVD works)
    Do I have a knackered SKY+ box or an incompatible amp
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I don't have Sky+ but these are what I would check first:
    Is Sky+ set to output audio via the optical output? Check the setup menu.
    Is the amp set to receive via the optical input for the TV input? If the DVD is ok then does the Sky work if the input is set to DVD? If it does you need to allocate the optical to the TV input.
    Mark.
  3. Pug72
    Pug72
    May 10, 2003
    1,992
    Hereford
    +277
    If you only have one optical input on your amp (which I doubt), you can get optical splitters from Homebase.
    They are designed to split a signal, but I have used it to share one input until I upgraded my amp.
  4. Stimpy
    Stimpy
    I only have one input on the amp.
    If I plug the optical cable into the DVD player I get sound, take it out and plug into the sky+ box, no sound (the optical light just flashes which usually means to signal).
    Think I may have a duff box. Are there any hidden settings to switch on the optical link (can see a rid light through the cable) or is it on all the time.
  5. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Assuming that you have fitted the cable correctly (it should click in to place), it does sound like a faulty box.
  6. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Have you assigned DD in the sound menu in Sky+.
    Jim
  7. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    He should still get sound through the optical link even if it's not set to output DD.
    I got output the minute I plugged in the cable.
  8. spinninghead
    spinninghead
    I had a similar problem with sky+ and a denon 3802 amp. turned out i had somehow deactivated the auto selection of the signal on the denon amp so the amp didnt detect the new signal coming in, either on digital or "normal" setting in sky+.
    has the marantz unit got a similar menu function?
