no sound on tv
Discussion in 'Cables & Switches' started by claudiong, Aug 13, 2013.
  1. claudiong
    claudiong
    Aug 13, 2013
    2
    I have connected my PC straight with a dvi to HDMI adapter and then using a HDMI cable.
    But have no sound
    And then went and purchased a digital optical audio cable but can't figure out how to get it to work
    Both my PC and TV have this input. Do I need to buy a different cable
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,471
    2
    +1,363
  3. claudiong
    claudiong
    Aug 13, 2013
    2
    Would this work with a home cinema system?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,501
    The Borders
    +3,468
    You require a suitable audio 'Output' socket on the PC – some folk will use the headphone socket to get stereo audio into your AV Amp with a low cost 3.5mm stereo to 2RCA cable – though that tends to be a less than ideal solution with the volume being variable and the headphone sockets often producing a fair bit of hiss at higher levels.
    You may want to look at a budget USB ‘DAC' (Digital to Analogue Converter) for stereo audio or USB Optical converter for 5.1 (if your PC supports it).
    Leave the DVI>HDMI cable in place to get video into the TV.
    Joe
