K
kbr88
I have a Pioneer PDP 427XD Tv that has been in the cupboard for a couple of years. i tried to set it up to test it and discovered there was no sound. The TV used to be connected to a Yamaha soundbar but that is no longer the case.
The TV is now connected via aerial. it's not connected to a stb or receiver. just the aerial. the picture is perfect and all of the functions work (EPG etc). i have tried all of the following:
-swapped aerial cables
-moved TV from one room to another to test the aerial outlet itself
-reset the sound 2-3 times
-reset to factory defaults twice
-checked minimum sound level
-checked mute
-checked source (TV)
Nothing seems to work. Am I missing something? Is it a hardware problem?
grateful for any suggestions
-checked mute
