No sound going to my sub...
Discussion in 'AV Receivers & Amplifiers' started by @if ®afiq, Jul 10, 2004.
  1. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
    I can't seem to get my sub to work.
    I'm using a MS309 with a Marantz SR5300.
    The cable I'm using is a diy sub with phono connectors.
    I've got two sub outs on my SR5300 - I've tried both but can't seem to get any sound out of the sub.
    The sub itself has an input for left and right - I've tried both of these as well.
    Am I supposed to have just the one cable?
    The sub is enabled in the AV menu...
    Help :lease:
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Is the sub set to ON or Auto:? Is there a green led glowing or a red one or none? If none check you have the plug in correctly and then if it is you migh have a blown fuse on the sub. Use the LEFT input on the sub.
  3. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    The sub can be left on at all times as it is a digital amp and consumes little power adn produces little heat. I have mine left on all the time, so does Tons of Fun with his 909's :D Getting a decent cable will make a difference. Look in the power buys section for Mark Grants cables . Superb quality at superb prices :smashin:
