No Sound from XE-1 to Onkyo 875 via HDMI?
Hoddle63
Joined
Aug 14, 2001
Messages
411
Reaction score
7
Points
256
Age
60
Location
Wrexham
As from title I just cant get sound from HDMI lead to amp. Audio is set at PCM for digital hdmi out. PS3 connected via hdmi lead and sound is awesome but prefer XE-1 working. Swapped same lead from PS3 to XE-1 but still no sound
Please help solve problem.
Phill
Phill
Hi Phill, have you changed the setting on the amp to tell it which HDMI is set for the HD-DVD?
Cheers for reply,
Yes the dvd is connected to input 2. All sound settings are last valid. This is what Game tv is set to for PS3 and multichaneel comes up on the amp screen and sounds brilliant, but xe-1 says no signal but the picture is fine.
I am totally lost now.
Phill
I had a similar problem on my 605. I couldn't get a full surround sound from my XE1. In the end I realised I had not changed the HDMI audio output option so that it didn't send the sound direct to the tv but via the amp. Make sure the audio out setting on the XE1 menu is set to auto. Also just check that you have assigned the HDMI socket the XE1 is plugged into and make sure you have selected the correct audio output on the remote(eg DVD, game etc)
Gav
Phill, the only other thing I can think of is, under the main menu on the amp, select option 7 (hardware setup), then option 5 (HDMI) and check that HDMI Audio is set to 'OFF'. A friend had changed this to 'on' thinking he needed it, but you don't and it can effect what your amp accepts from the player.
Cheers Urban T
I know have multi channel on my HD player and now can sit back and enjoy new films.
Big thank you for your time and help.
Phill:clap:
Lyngdorf MXA 8400 - Premium Power Amp Review Teaser #homecinema #poweramplifier #hometheater
Back
