No sound from motherboard jacks - any ideas?
Discussion in 'Computer Components' started by Triggaaar, Aug 31, 2005.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    I'm trying to get basic sound from my motherboards 3.5mm jacks. I've gone through the XP troubleshooting guide, but can only verify that sounds play from the M-Audio 2496 I installed.
    Notes:
    My motherboard has 6 jacks - I have checked I'm using the correct one, and have also tried the others incase.
    My speakers are working.
    I assume my sound settings have disabled my motherboards outputs in favour of the SC, but I don't know how to allow both (the same would presumably apply to the motherboards SPDIF, but I haven't got that far yet).
    Any ideas? Thanks
  2. The Dude
    The Dude
    May 21, 2004
    6,170
    Beverley, East Yorkshire
    +2,452
    I dont think your onboard sound will be available at all with a seperate soundcard installed... I could be wrong though.
    try going into sounds and audio devices, and selecting the onboard sound as the playback device in the audio tab.... doubt it will work though..?
  3. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    Onboard sound isn't listed in the playback drop down list.
    Is that it? Install a soundcard, and then you can't use your motherboards sound options? Seems silly not to be able to configure things as you'd like.
  4. The Dude
    The Dude
    May 21, 2004
    6,170
    +2,452
    you could argue it would be silly to install a new soundcard and then try to use the old one... ;)
    You've got SPDIF on the MAudio, so you'll still be able to use your 5.1 speakers/ AV amp..?
  5. BenW
    BenW
    Jun 3, 2005
    876
    Stansted
    +17
    I can use my onboard and sound card at the same time.
    Check onboard is enabled in the bios
  6. nismoskys
    nismoskys
    try checking your onboard sound driver as well, maybe reinstalling it might work
  7. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    My motherboard is the Asus A8N SLi Delux. I can't see an option in the Bios for onboard sound.
    Unless the board is broken (unlikely I'd guess) I assume the soundcard has disabled it, but there must be a way to have both active?
  8. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    :rotfl:
    Ah dear boy. I think what you meant to say was 'maybe INSTALLING it might work'.
    It seems that I didn't know what Realtek was, so I didn't install it :suicide: Thanks :)
    Can't get the staff.
    From the Sounds and Audio Devices Properties, it seems I can only enable one method at a time though. Did you find a way round this Ben?
  9. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    it depends on the software you are using. If it recognises multiple sound cards then it can choose the right device every time. Not tried it myself though so maybe other forum members know which software does this.
    Ahh scratch that, I know Zoom Player allows me to do this as in advanced mode you can choose the output device, so it lists "Default Direct Sound Device" and "Audigy 2" so if I had another device eg motherboard, then I could choose that. Default would mean whatever you have set up in Control Panel -> Sounds.
    An example of other software that does do this (although not relevant to HTPC use) is Skype. This can be configured to use either the default device or something like a USB Audio Device eg USB Handset or Headset.
    Rajiv
  10. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,526
    Near London.
    +208
    The built-in soundcard shouldn't have disabled itself just because another card is present. In the days before full-duplex it was common to need multiple soundcards working.
    I can only guess that the problem is either in the bios/jumper settings or a driver problem. Scanning for new hardware might help. :)
  11. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Suggest you read the post eviljohn2;)
  12. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    This happened on my friends machine, it was a *cough* Gigabyte board. I removed the PCI sound card, uninstalled it, installed the drivers for built in sound card, the software detected it, the windows control panel listed the soundcard in the play back devices, but yet no sound came out...
  13. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    I really appreciate the fact that you're overlooking the fact that I'm a complete idot. Cheers :thumbsup:
  14. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    no its ok. I have a long memory!
    Oh meant to add, depending on your use, if you have to use a program that can't switch then make it the default and use programs which can for the other sources.
    Rajiv
