No Sound from DVD
Discussion in 'Computer Components' started by Snash, Nov 5, 2005.
  1. Snash
    Snash
    Sep 6, 2005
    84
    9
    Hooked up HTPC to 32WLT58. Sound fine from normal TV but nothing from DVD? Any ideas?
  2. Matt.Wild
    Matt.Wild
    Mar 28, 2005
    3,271
    71
    Walsall
    +87
    Do you have a lead runing from the back of your dvd drive to your sound card? If not, that is why. The ide/scsi leads don't carry sound...
  3. Snash
    Snash
    Sep 6, 2005
    84
    9
    /Hides face in shame and shuts down to check :rolleyes:
    EDIT - hang about I get sound no problem with it if played through PowerDVD outside of MCE
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    That is most certainly not the case anymore. It is the MCE cofiguration, but never having really played with it I can't suggest how you would put it right.
  5. Snash
    Snash
    Sep 6, 2005
    84
    9
    Thanks guys got it sorted now. Under DVD settings in MCE under Audio I changed the Speaker Environment from 2 speakers to Headphone on the basis that I'm using single 3.5mm stereo jack to the tv. It worked and it sounds okay.
