No sound from DVD-R disc. Why?
Discussion in 'Blu-ray & DVD Players & Recorders' started by finnis, Sep 22, 2004.
  1. finnis
    finnis
    Dec 26, 2003
    79
    Recorded some prgogrammes using Sky+ which I transferred to DVD-R for a work colleague, using Panny e55. Works fine on my machine and my other Panny player. Picture is fine when playing in her machine, but there's no sound. She has a Goodmans player, I think.
    Any ideas?
  2. Techno
    Techno
    Nov 20, 2003
    312
    I've just found this when I've recorded some stuff off sky onto +R. Plays back fine on DVD Recorder and on PC, also plays back OK on my Yamaha player connected via scart to TV but no sound using the same Yamaha player connected to my Plasma via Yamaha Amp.
    I wonder whether this is something to do with the way the sound is recorded which doesn't then play back via digital only sound connections.
    Drives me mad.....
  3. Zedmeister
    Zedmeister
    Sep 9, 2004
    60
    11
    Could be something in the playback settings. The E55 encodes audio onto the disc using Dolby Digital 2 channel. Any player then playing back the disc must be set up accordingly to either pass the audio as a bitstream to an external decoder (amp) via the digital output or decode it itself and pass out the decoded audio either via PCM on the digital output or analogue audio via SCART/phonos.
    You'll have to further investigate her setup to find out why, I guess.
  4. finnis
    finnis
    Dec 26, 2003
    79
    Thanks. Had a feeling it must be her setup as it works fine on my setup and I've also done some DVD-r recordings for my dad a few times and they've worked fine. He does have the same panasonic player as me, though, so I guess it would work!
