johnr2110
Re-connected my mother's DVD to the TV using scart. Picture but no sound. Broadcast TV as sound & vision. Any ideas?
Make sure it's fully seated.Re-connected my mother's DVD to the TV using scart. Picture but no sound. Broadcast TV as sound & vision. Any ideas?
Try another scart cable or reverse the existing cable.I'm informed that all cables are secure
Thank-you f0r that information. I'ii pass it on.Has she swapped the cable at all. Some scart leads had the audio wires removed to improve the visual quality. The assumption was that the sound would be then connected via an optical cable instead. Obviously if the latter is missing then no sound in this case.
