No sound - can anybody hear me!
Discussion in 'Plasma TVs Forum' started by markwhiteside99, Aug 1, 2004.
  1. markwhiteside99
    markwhiteside99
    I have just connected up my Panny TH-42etc through a Yamaha AV Amp, to a set of Missions speakers. Also into the amp is a Yam DVD player.
    When I use the DVD all is well, and the missions work wonderfully. A different story when it comes to Sky however. I have the digibox connected via scart to a JS Technologies box of tricks (RGB to component), which then goes via component leads to the amp. The amp then goes to the plasma via component using the monitor out connections (from memory).
    Given that the DVD works just fine, which is also connected to the amp by component, and then to the screen by the 'monitor out' components leads, I assume it is a software setting. . . . . . either that, or I am a cable down somewhere and I will shoot myself, as all the cables are now plastered into the wall!!
    Has anyone got any ideas if possible, its so frustrating as I am nearly there.
    Any help much appreciated,
    Mark
  2. idhutt
    idhutt
    Correct me if im wrong, but component carries video not sound. The monitor out designation sounds as if its for a video monitor. Unless you have audio from your $ky box connected to your amp, you are not going to get sound. I suspect that your DVD player already has a separate audio connection in addition to the component video, which is why you can hear it.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    very true need audio feed from Sky to amp or can go from JS box, they have audio outs too.
  4. markwhiteside99
    markwhiteside99
    Thanks Guys, if it was not obvious from the question, I am new to this.
    Anyway, audio now going from JS Tech box to Amp, and all is well. Am very please with results, I have to say.
    Will post pictures if I get chance, and can learn how to do it!
    Thanks again,
    Mark
