no sky sound from my denon 500
Discussion in 'Home Cinema Buying & Building' started by Riss71, Mar 31, 2005.
  1. Riss71
    Riss71
    Mar 11, 2005
    33
    Somewhere in Cardiff
    I have pic but not sound from sky.
    My set up tosh 46wm48
    denon 500
    sky amstrad
    2 scarts
    at the mo the denon is linked to tv via scart and the denon is linked to the tv via scart, my brian is totally fried :suicide: been setting this up since tea time yesturday.
    Do you think i should connect my denon up to the tv via commponant leads and sky to the denon via scart, somebody anybody help meeeeeeeeeeeeee!!!!!, im going nuts
  2. Paul Philpott
    Paul Philpott
    Mar 13, 2005
    459
    Newhaven
    +58
    Hi Try connecting the sky+ box to your Denon using an optical lead. This has the added benefit of giving Dolby Surround on sky/disney channels!!
  3. Riss71
    Riss71
    Mar 11, 2005
    33
    ive only got normal sky, any other ideas ?? :lease:
  4. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Just connect phono leads (red and white) from Sky to one of the video inputs on your Denon, then select that input.
    Alternatively if your tv has phono outputs just connect these to the Denon inputs. Then anything that you connect to your tv will have its sound outputted to the Denon.
  5. whuelse
    whuelse
    Jan 4, 2005
    29
    4
    I know the feeling Riss.
    Hv u tried switching the "input mode" using the remote for the 500SD? This loops through PCM->DTS->ANALOG->AUTO
    Let us know
