No SKY Q Remote
stevieb333
Hi, Could anyone tell me if it is possible to change the channels on a SKY Q box without using the remote control. In other words are there any hidden buttons that will operate
the box in the same way that the remote control does.
Many thanks
Steve
Russ_64
No, there are no controls on the box. You can buy remotes from Sky or other sites incl. Amazon
stevieb333
Thanks Russ64 I thought that might be the case. I take my q box to my caravan and forgot to bring the remote :confused: Luckily enough it is stuck on Sky Sports, so I'll just have to put up with the Mrs moaning for a week! !:lesson:
busterbenny2001
Now there’s an idea,,,,,
Slider09
Isn't there a phone app?
jonoro
There is indeeed. It works well, your phone needs an IR port.
Just goggle for
app android remote sky q
Pick the SKY Remote Control. Icon in blue square with remote and 2 wifi like arcs.
TV selection in it (for volume control) is very limited.
Similar threads
