no signal
B
bozzly
Hi all
After watching freeview for a couple of years now with no problems I have suddenly had a problem with the ITV's and CH4.
For the last two days I get the message on screen ' no signal '
Does anyone know what the problem might be, or is the multiplex down or something?
I live in Clacton On Sea, Essex if that helps
fernandez
Any sort of problems on other channels and what make/model of receiver?
Have you checked the aerial/cable/connections.
Have you or can you either try the receiver at another location where you know reception is OK
or
can you try a different receiver connected to your existing aerial?
At least that would eliminate several areas where a problem may be
Disconnecting the receiver from the mains for a few minutes and then a rescan after reconnection sometimes helps and is worth a try
