No Signal on monitor until I reboot.
Discussion in 'PC Gaming & Rigs' started by Foster, Dec 13, 2017.
  1. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    Its been happening for about a week now, and i'm none the wiser what is causing it. I'm connected via DP so I tried it with HDMI, but it does the same thing.
  2. SuperSportBilly
    SuperSportBilly
    May 18, 2004
    2,381
    83
    +490
    AMD card ?
  3. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    Nvidia, 980Ti to be precise.
  4. IRobot
    IRobot
    Jun 28, 2006
    1,891
    116
    Leamington Spa
    +1,065
    I had a similar issue with an EVGA 980 and Phillips 4K monitor. If you wake the PC from sleep, the monitor wouldn't turn back on until a hard reset. Got a graphics card firmware update from EVGA which fixed the problem.
  5. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    I've just updated my drivers and it seems ok, I shut it down and restarted it a few times, i'll see how it is over the weekend!
  6. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    and nope its at it again :|
  7. sykotik
    sykotik
    Sep 8, 2008
    7,112
    co. durham
    +2,271
    I had this a while back , re-seating the GPU worked for a bit , but in the end i ended up reinstalling windows and that seemed to work .
  8. vorsies
    vorsies
    Oct 29, 2017
    7
    4
    Manchester
    Have you tried using DDU (display driver uninstaller)? Not sure what the policy is in this forum about posting external links. It automatically boots you in safe mode where it uninstalls all traces of nvidia drivers, and then you can install them fresh
  9. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    No I haven't tbh, but I will try that.
  10. vorsies
    vorsies
    Oct 29, 2017
    7
    4
    Manchester
    If it's a software issue, this has the highest odds of fixing it.
    What's the context when this is happening? Does it happen when it's underload or when idling? I'm asking cause it could be a temp issue. If DDU doesn't fix it, check temps, and you could also use process of eliminition to see if it's the GPU or the monitor at fault (assuming you have the capacity to do so)
  11. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    iT is at startup so after the ASUS splash screen but before the windows splash screen the screen goes black and no signal on the monitor.
  12. vorsies
    vorsies
    Oct 29, 2017
    7
    4
    Manchester
    okay that makes it more interesting. The chances of it being a driver issue have decrease. From a quick search I've done online most people found their solution by resetting their BIOS/UEFI settings.
  13. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    I'm hoping it is software and not hardware, I'll see how the driver wipe gets on and go from there.
  14. sykotik
    sykotik
    Sep 8, 2008
    7,112
    co. durham
    +2,271
    What mobo are you using? how old is the mobo ? ,
    i had a problem with my z97 msi gaming m board , because of the weight of the GPU's that i had in there over the years , the main PICe slot became very temperamental, if i propped up the GPU so that is straight it wouldn't work, if i just let the gpu sag if would work somethings ,
    refitting the gpu a few times, it would work ,
    try an other PICe slot if you have one if it works straight away in the second slot then the 1st PICe could be the problem .
  15. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    I've just noticed before it goes black windows says shutting down...
  16. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    The model is in my sig (on phone so cant see) but its 5 years old. Im thinking its a windows issue now with it saying shutting down at startup.
  17. sykotik
    sykotik
    Sep 8, 2008
    7,112
    co. durham
    +2,271
    Haven't got the sigs shown on my screen ( turned them off )
    sound like a reinstall is needed .
  18. alphaomega16
    alphaomega16
    May 17, 2005
    14,148
    163
    Southend on sea
    +3,771
    That is his sig.
  19. Foster
    Foster
    Sep 25, 2011
    16,113
    2
    West Yorks
    +7,312
    Well after disabling quick start at windows startup it hasn't done it since.
