No signal on certain Sky channels
Discussion in 'Sky Digital TV Forum' started by Nick Odgers, Oct 28, 2003.
  1. Nick Odgers
    Nick Odgers
    Apr 11, 2002
    315
    +22
    I have "no signal" message on channels 440 - 448 and Paramount 2. Others are o k. I am using Sony digibox, the signal strength jumps from 40 to 50% and back, signal quality stays around 75%.
    I brought an old Pace receiver down from the attic and got "not locked" message when I connected it! There is a tree in the garden could this affect just certain channels?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Well the MTV family of channels are all on the same transponder (TP10 on the 2A south beam). Paramount2 is also on 2A but on transponder 11 north beam.
    When you say the other channels are ok exactly what does that mean, every single channel or just the ones you watch? If you are a movie subscriber check Movie Max 2 & 3 which share a transponder with Paramount2.
    A tree would certianly degrade the signal as long as it was in the line of sight with the satellite but you would expect the problem would be global and not effect only a few channels.
    Perhaps there is a weakness in the cable which is affecting the frequency that those channels use or maybe some external interference (DECT phone) which has been known to cause selective problems.
  3. mr_blah
    mr_blah
    Sep 24, 2003
    39
    9
    I have a loss of a few music channels - Kiss, Music Choice, Q, TMF and channel 250, am getting a new lmb because there maybe a fault with the one i have now, also it was doing the same thing with my sony box and the first sky digibox i had, so i know it must be the cable or LMB.
  4. rich tee
    rich tee
    May 30, 2003
    415
    Bristol
    +7
    Err, What's a LMB?
    Rich Tee.
  5. Nick Odgers
    Nick Odgers
    Apr 11, 2002
    315
    +22
    Thanks for replies. My dish is on a pole in garden and I think sister`s dog must have knocked it because moving it down got mtv back, but paramount still breaks up.
  6. Fernsehman
    Fernsehman
    It stands for "Low Moise Block-downconverter". Heck, everyone knows that! :D
    By the way, leaves can cut out a few transponders but not others.
  7. roadtorode
    roadtorode
    Feb 15, 2005
    27
    I too have a "no satellite signal is being received" on Paramount + 1 (I think); all other channels are fine (well, normal anyway !) What might cause this guys ? I do think that maybe my dish needs re-aligning, because the signal goes far too easily in the rain, imho, and the strenght and quality is pretty low. Are these two things likely to be connected ? :lease:
  8. Nick Odgers
    Nick Odgers
    Apr 11, 2002
    315
    +22
    Since writing that post two years ago I have had Sky + properly installed with a new minidish on side of house and now have no problems with any channels, I think you may need to do the same roadtorode. It sounds as if your dish is slightly out.
  9. roadtorode
    roadtorode
    Feb 15, 2005
    27
    thanks, I guess the golden rule is to get an independant specialist to do it, not a Sky operative (he said, choosing his words carefully...!) :cool:
