NO signal in the rain
Discussion in 'Satellite TV, Sky TV & FreeSat' started by peacemf, Aug 28, 2005.
  1. peacemf
    peacemf
    Aug 28, 2005
    23
    hey
    newbie :)
    ive had sky digital for ages!!!
    but, the problem is that the dish looses signals completely in the rain and on a cloudy day, is there anything that i can do to solve this?
    Also how long does it take for your reciever to start up and show a picture?
  2. JayCee
    JayCee
    Jan 20, 2004
    20,208
    Lanarkshire
    +1,932
    Sounds as though you have a very poor signal due to poor dish alignment, a faulty lnb/downlead or combination of all 3. You need to call in an aerial rigger.
    If switched on from standby (which is the way it's designed to be used)...instantaneous.
    If switched off at mains supply and the switched on.......a couple of minutes.
  3. nicke20
    nicke20
    Oct 11, 2003
    874
    +13
    what is your signal strength graph showing ?
  4. peacemf
    peacemf
    Aug 28, 2005
    23
    hey
    thanks for replying...
    signal strength is never above 50%
  5. nicke20
    nicke20
    Oct 11, 2003
    874
    +13
    if your dish is easy to get at, you can get very good results with a friends help just nudging the dish around, ie up down and left right on the mount keeping an eye on the two bar charts. Ive never used a "rigger" yet, why pay someone to point a dish ?
  6. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    I went up and looked at my dish when I was having this problem. Cabel had gone rusty in the LNB :eek: Cut cabel and used 3rd LNB feed.... ;)
  7. nicke20
    nicke20
    Oct 11, 2003
    874
    +13
    there you go, another possible problem from the "that will be £80 please school of dish fixers" go on try diy
  8. Steve999
    Steve999
    Jan 12, 2005
    35
    Lincolnshire UK
    Wrap the 'f'pug connection in self-amalgamating tape to prevent rusting and water access.
    Steve
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    ........ then wrap the self-amalgamating tape in PVC tape because s-a tape goes brittle under direct sunlight :)
