R
rideblue
Hello to all.As a new member I'm using my first post to ask for help and advice. I've just bought a 37LG6000 and have been attempting to set it up using my Virgin+ box. Firstly I used one of the HDMI inputs to connect the v+ box and then attempted to auto tune the TV but with no success,the screen informed me " no signal ". I then proceeded to attempt connection using each of the other HDMI inputs in turn and then the scart inputs,all with the same result. I connected my DVD player via the HDMI input with no problem at all but the signal from the V+ box is not getting through no matter which input type I use. If anyone has any knowledge of this problem and any solutions I would be most grateful for the input,thanks.
