redroadster
Evening All.........
Help..Please (if you can)
Lost all my freeview channels on 4 tvs.. There fed via a Glbal Comms Professional Loftbox.. connected as...
1 x sat ant, 1 x living room, 1 x DAB ant, 1 x TV ant, 1 x FM ant, plus 4 x tv outputs...
To try and establish if the loftbox is knackered, I took a tv into the loft, hooked it up direct to the TV ant (away from the loftbox) and found freeview channels. Then i hooked up one of the tv outputs direct to the TV ant and that room could then pick up freeview channels.... On top of this I then put a length of co axial to act as an ariel in one of the TV`s and that picked up freeview channels...
From this, could one assume that the Loftbox is broken.....?
Many thanks in anticipation...
Nige............
Nige............
