"No signal" error on a few channels..
Discussion in 'Microsoft Windows' started by crE, Mar 19, 2006.
  1. crE
    crE
    Hi, I'm not sure if this is a common problem.. But..
    I'm in the UK, I'm having trouble recieving about five channels... I know these channels work because they work through WinTV software and via the freeview box...
    I'm using a Hauppage WinTV USB reciever.
    Everything else is great within media center!! Recordings etc.. Has anyone any idea why this is happening?
    Everyother channel is working fine, great quality.
    I'd appreciate any help you guys can give me..
    Regards,
    Nick
  2. WheresMyArtisan
    WheresMyArtisan
    Mar 14, 2005
    1,100
    48
    +71
    I've heard it said that Media Center can be less sensitive than the card maker's own application. I find this a bit difficult to believe, but there you go. Possibly a load of old rubbish, but it would explain your problem.
  3. BigBry
    BigBry
  4. spin20vt
    spin20vt
    Jun 7, 2005
    116
    +7
    Yea im getting this on all of the bbc channels now, but they used to be fine and they are fine on my built in tuner on the tv, any ideas?
