'No signal' cut-out on PWD6
Discussion in 'Plasma TVs' started by maxzorin99, Jan 19, 2004.
  1. maxzorin99
    maxzorin99
    Don't know whether you guys have come across this problem before.
    I currently have a panasonic PWD6 display, connected via a component cable to a SONY 735d DVD, which is 'auto-region-switching'.
    On some DVDs the picture seems to cut out, giving me a momentary 'No display' message on the plasma, or a quick screen blackout - and then the picture is back again. Its difficult to pin-point when it happens on each DVD, but it does happen for region 1 and 2 DVD's.
    When I switch to SCART connection, the problem does not occur, yet i know that component cable should work just as good.
    I've been told that because the DVD player is auto-switching ('chipped'), it could be that the DVD player that is causing the problem. Does the PWD6 plasma work with Sony DVD's - or is there a compatability issue? and have you come across this problem before? I haven't been able to swap one DVD player with another cos most of my mates DVD players are the same as mine!
    emailed Panasonic with the issue last week - no response!
    If i do need to get another DVD, what would be ideal? Panasonic S75, Harman Kardon 25??? - all i want is the ability to play region 1 and 2, and NTSC/PAL progressive output via component.
    Any help would be greatly appreciated. Thanks.
  2. daveb975
    daveb975
    Oct 25, 2002
    3,875
    103
    London
    +252
    Can't help with this directly, but I don't think that the PWD6 display has any problems with Sony DVD players.
    I have my Sony 900 connected to my PWD6 via component, and have not experienced this problem.
    Have you tried removing and re-seating your component board?
  3. maxzorin99
    maxzorin99
    Cheers Daveb975
    IMO, i think it comes down to 3 things - the DVD player, the component cable, or (as you say) the component board.
    I'll re-seat it at the weekend, i'll be buying a new DVD soon, so that will eliminate the DVD player.
    its a very intermittent problem, but it does mess up your viewing somewhat!
  4. KevinR
    KevinR
    Mar 19, 2002
    102
    16
    Durham
    Same thing happened to me. I connected a multiregion Toshiba 330 to my Panny using a £53 component to vga cable. The signal seemed to be lost in scenes when there was a lot going on - explosions etc. I thought my sub might be affecting things but it was still the same when switched off. Then I swapped out the DVD player for another one - same thing so I assumed it was the cable and went back to scart - trying to convince myself the picture was as good, it wasn't.
    So I thought the cable was defective but I haven't got round to doing anything about it yet.
    Assuming the cable is OK, does this mean the Panny can suffer problems when fed a component signal? Anyone else?
  5. maxzorin99
    maxzorin99
    come to think of it, the scenes where it was happening were quite bright and had strobe lighting combined with explosions.
    It happens quite a lot on the ALiens DVD (the legacy collection) in the shootout scene ( i think its a chapter called 'Game Time') - a great scene spoiled by this annoying problem.
  6. Timmy B
    Timmy B
    This happened to me with my Toshiba 510. It happened no matter what connection, prog. scan or interlaced.
    Spent 2 weeks on the phone to panny, everyday. They finally told me that they only support DVD players made by Panasonic, and advised I get a refund, which I did.
    Panny custom support really is atrocious, then again my dealer was even worse!
  7. maxzorin99
    maxzorin99
    TimmyB - did getting a panasonic DVD solve the problem?
  8. Timmy B
    Timmy B
    I don't know, I didn't try one. I got a refund and purchased a Fujitsu vha20, based on the series 5 glass. My toshiba 510 played fine on this.
  9. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Am using arcam dv88 via component had no problems up to now
    on pw6, did notice sound drop-outs when using dv88 on my old pw5 with off-board tuner on dolby digital as well as dts againnvia component to tuner and vga to the screen
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    It does sound like a dvd problem, the tosh problem is now quite well documented. Have you a mate you could swap players with to see if the problem goes away? Or a very friendly dealer?
  11. maxzorin99
    maxzorin99
    i'll try and get one - i've got a few things to check out at the weekend on this.
    You cannot rule out a faulty plasma screen, but i really hope it is the DVD, cable or component board that's faulty.
  12. maxzorin99
    maxzorin99
    checked it at the weekend - swapped the cable, reseated the board, even tried putting it in slot 2 and not 3.....no change in the problem.
    So, it must be the player. I need to buy another one anyway - probably the Sony 730 or HK 25, with NTSC/PAL PScan.
  13. maxzorin99
    maxzorin99
    Just got back from av-sales. Liam and me went through the tests with a denon DVD, trying the Aliens DVD, and the problem was still there - but when we changed the signal from interlaced to progressive - the scene progressed as normal, with no cut-out.
    Bit surprising that - but at least it means I am definately getting a progreesive scan DVD player now. that's the only way it can deal with these DVDs.
    thanks for all your help!
  14. gpa
    gpa
    Just a note for you, i have had no problems with sound or picture drop out on my PW6, sorry i cannot help more.
