No signal being received
Discussion in 'Satellite TV, Sky TV & FreeSat' started by martynanstis, Jul 13, 2005.
  1. martynanstis
    martynanstis
    I was using a Pace Sky+ box in the Czech Republic until about 2.5 weeks ago when all but one channel displayed 'No signal being received'. As I am only using one LNB out here and not using the phone line I am unable to check for updates. Has there been a big upgrade or change to the frequencies within this time??
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    No major changes, as far as I'm aware. What channel can you still get ?
    By the way, you don't need a phone line to get updates, they come via the dish. Just remove the power, press and hold the backup button, and re-apply the power, keeping your finger on the button until you see the on-screen display. However, it might not be advisable to do this if you have a possible dish alignment problem or LNB fault !
  3. martynanstis
    martynanstis
    I can still get channel 145 UKTV Food. Have had the dish re-aligned and a new LNB as I thought this was the problem. Thanks for the info about the phone line and I will try a reset tonight. If this doesnt work I am back in the UK this weekend anyway.
  4. martynanstis
    martynanstis
    Tried the reset as you suggested and it worked OK. Many thanks for your help and its saved me lugging the box half way across europe this weekend.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Excellent ! :thumbsup:
