  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
No scarts left to connect another receiver
Discussion in 'Cables & Switches' started by js1, Jul 22, 2005.
  1. js1
    js1
    Hello. I have a Plasma TV (with no tuner). The dvd recorder acts as the tuner using a scart from the dvd and
    bnc connection to plasma. The other scart on the DVD is linked to the sky
    box. The dvd (Toshiba xs32) has 2 scarts so these are both used. I need to connect another satellite receiver so that it links to both the sky and dvd but there are no more scarts on the dvd.
    There are 2 scarts on the new receiver. Could anyone tell me how best to set this all up please? Would I have to use say scart from new receiver with component/phone cables on the end to plug into DVD? Would this work and give a decent picture still or is there a better way round it all like using a hub for example.
    thanks for any help.
