no scart, no freeview?
Discussion in 'Freeview & YouView' started by jakedillon, Feb 15, 2005.
  1. jakedillon
    jakedillon
    Recently purchased a Matsui dtr 2 recevier, connected it to the bedroom tele', but couldn't tune tv to digibox. I contacted the Helpline number, to be told that it needed a scart connection to work. As I have a tele' without a scart connection, I was told that I'd have to take it back, was also told that all tv's sold now have scart sockets! Well I know this is not true, my question is can I buy a digibox that plugs into an old fashioned tv. :confused:
    Regards ....Jake
    l
  2. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,048
    83
    a place that haz no reconz:(
    +296
    you need a box with a built in rf modulator such as the pioneer or sony both of which I believe can work on tele without scart.
  3. jakedillon
    jakedillon
    zaheer86
    Thanks for the speedy reply, I only joined this forum about 25 mins ago! Already a resullt! Will take on board your info, it's better than you can get in Currys!!!!!
    Regards....Jake :thumbsup:
  4. Shwing
    Shwing
    Feb 1, 2005
    128
    +9
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    If the TV is new I would suggest taking that back. I have a feeling Freeview over RF wont be very good picture quality..
    Richie.
  6. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    The Sony (I'm assuming you're referring to the VTX-D800U) does not have an RF modulator.
  7. pinatubo
    pinatubo
    If you can get one ,you could try the Philips DTR100 which does have a RF modulator as does ,I believe, the DTR 500.
    However, the DTR100 doesn't have an EPG as yet.
  8. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,048
    83
    +296
    :oops: sorry for the misinformation!
  9. jakedillon
    jakedillon
    Thankyou to all who have given me info, much appreciated! :thumbsup:
    Regards.....Jake
  10. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,955
    Reading
    +307
    All the Setpal's have a modulated RF output.
  11. Marcon
    Marcon
    Dec 26, 2004
    3
    Jake,
    The Pioneer box certainly does have an RF modulator and will work on a scart-less TV. When I tried it picture quality was fine, not as good as through a scart, but perfectly watchable.
    Pioneer have just updated the software for this box (to v 1.6) and so it now supports the 7-day EPG.
  12. hao
    hao
    Picked up a Thompson DTI2300, from Argos, which indeed dose have an RF modulator and gets superb PQ. However tried it with a TV set having no scart, after setting it to RF in the menu, but was unable to tune into it. When I connected it back to a scart TV it had reset to scart RGB with RF off. Any soloutions?
