no satellite signal being received??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by killer10971, Feb 9, 2009.
  1. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    for the last three days ive had this when coming home from work and taking the samsung box out of standby,never had any problems with the old sky+ box ,pull the power lead for a minute or two and back to normal
    any ideas anyone :lease:
  2. The Dark Horse
    The Dark Horse
    Jan 28, 2004
    4,306
    +847
    Me too !!!
    I posted something earlier about it but didn't get any replys. It has not recorded a couple of programmes, I'm getting a 'failed' message or 'no signal' message. Or I loose all the channels and get 'no satellite signal being received' message ???
    I have to unplug it as well...any ideas anyone?
  3. kevmarshall
    kevmarshall
    Apr 11, 2006
    1,609
    Lincolnshire.
    +209
    A simple SEARCH on this forum for "no satellite signal being received" will bring up several threads on the subject.
    As you have Samsung boxes I assume you are still under warranty with Sky so give them a call.
  4. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    i did a search and there were several threads on swapping inputs ,power off lnb , and psu failure
    signal strength and lock all ok ,other sky+ box on the same dish ok
    just wondered if there was a obvious option as it was a bit odd its done three days on the trot (box in standby during the day)
    as you have posted a comment regarding samsung boxs and warranty is this a terminal problem ???
    cheers
  5. kevmarshall
    kevmarshall
    Apr 11, 2006
    1,609
    Lincolnshire.
    +209
    I just meant that Samsung boxes are a fairly recent addition to Sky so the chances are you are still in your 1 year warranty for a replacement. :smashin:
  6. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    yes installed november 2008 ,ive just tried swapping inputs so ill see how that goes
    "THE AMATUER" if this sorts it ill let you know or if i find another solution
    cheers
  7. The Dark Horse
    The Dark Horse
    Jan 28, 2004
    4,306
    +847
    I rang Sky and they went through a few things, reset some settings, unplugged the wires and put them back, then unplugged the box and powered it back up. It seems to have done the trick (well so far anyway) because I could only get ITV1 to work before this.
    They did say if it happens again they will get an engineer out so it may be worth you ringing them to get it noted on your account.
  8. Baldster
    Baldster
    May 6, 2004
    116
    +4
    I've been getting this lately on numerous channels, particularly Sky 1 and BBC HD. Also no signal on one or other or both channels, despite dish being fine. Re-boot (sometimes) sorts it out.
    Have original Thompson box so well out of warranty.
    Phoned up on Sunday and explained that I'd just started getting problem, and had heard that lots of similar problems out there.
    Engineer visit was arranged v quickly for today, new box swapped in, no callout charge asked for or box cost. Very impressed for once.
    Hope this helps someone else with similar problem.
  9. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    got in today and bloody box is locked up again with no sigal being recieved
    all ok last night
  10. The Dark Horse
    The Dark Horse
    Jan 28, 2004
    4,306
    +847
    get on the phone and report it, it must be something to do with HD because I never had this problem before? Mine has been ok since speaking to sky tech help (fingers crossed !!!)
  11. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    spoke to them tonight ,change inputs ,power down lnb ,try this try that etc ,everything i tried from reading on here
    ill give it another night if its locked up tomorrow then its an engineer job
  12. Bernie Steak
    Bernie Steak
    Sep 1, 2005
    513
    +18
    Risking stating the obvious...
    The dish/LNB doesn't have a load of snow/ice on it does it? Ours was taken out last night due to the weather!
  13. jdedward
    jdedward
    I have an Amstrad box which has just been replaced after my last box developed a fault.
    When it claims it has no signal when flipping through the channels I checked the details in the Service menu and it says it has its usual amount of signal. If I turn the box off at the mains and back on it then find the signal its looking for. If I put the box into standby for about 5/10 minutes and put it back on it also find the signal.
    It is really annoying me. I also have a communal dish set-up, so its hard to get Sky or the dish owners to actually help.
    :thumbsdow
    JDE
  14. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    no snow as it melted in the tropics known as essex after about two days from the first load of snow ,no birds either
    it was working ok"ish" apart from lip sync ,the old sky+ box never a problem ,its since we had hd
  15. JayEm
    JayEm
    May 5, 2006
    567
    North Yorkshire
    +16
    I'm getting this but only on Bravo, Living and Trouble. Is it a coincidence that these are all owned by the same broadcast company (if I remember correctly)?
  16. daz606060
    daz606060
    Nov 9, 2007
    214
    hull
    +47
    i'm getting the same with bravo/+1 living/+1 challenge
    EDIT:there back but braking up constantly?
  17. JayEm
    JayEm
    May 5, 2006
    567
    North Yorkshire
    +16
    Good to see it's not just me. They seem fine on the regular Sky box in the the other room though.
  18. EternalMovement
    EternalMovement
    May 28, 2008
    59
    Paignton
    +14
    Same happening here.
    channels 254 and 255 not working for everyone else to?
  19. rawdonwhite
    rawdonwhite
    Feb 23, 2008
    3,095
    Rawdon, Leeds
    +446
    the only problems i am having are with all of the discovery group of channels (i'e home and health, discovery knowledge, turbo, science etc) - though most of discovery's + channels are ok (except discovery +1) ?. all other channels seem to be fine
    so i guess there is a problem at skys/discovery channels end (time for somebody at sky to switch the discovery transponder back on)
  20. themoron
    themoron
    Jun 30, 2001
    234
    Christchurch, Dorset
    Same here (Bravo, Discovery, etc) on SD box. Shame, as Bravo are showing a Star Trek I dont think I've seen :eek:
  21. Adamnjsdad
    Adamnjsdad
    Dec 31, 2005
    93
    +26
    I, too, seem to be missing most of the Discovery channels Has someone found an off button I know nothing about!!!
  22. Adamnjsdad
    Adamnjsdad
    Dec 31, 2005
    93
    +26
    They have found the on switch again!!!
  23. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    I have a none HD Sky+ box at the mo (until HD comes tomorrow that is) and gets. I find switching off at the mains and back on again normally doe the trick :smashin:
  24. tigermad
    tigermad
    Jan 2, 2004
    6,359
    Bedfordshire
    +644
    You got everything for free even though your box is way out of warranty? Thats a first! :)
  25. killer10971
    killer10971
    Dec 29, 2004
    1,123
    +36
    right after trying everything ,one at at time the solution which seemed to maybe of worked was powering down lnb ,saving ,then power on save.
    my box was not allowing me to watch anything unless i pulled the plug and then it was fine until the next day
    havnt tried it today though :eek:
  26. dfisher_uk
    dfisher_uk
    Nov 16, 2005
    459
    28
    Edinburgh
    +40
  27. PaulRamon
    PaulRamon
    Jul 22, 2008
    2,968
    +227
    A milion thanks for the above information. I recently had to replace my faulty thomson box but I bought another Thomson! I only have one feed as its in a spare room. Today I received the new planner and got the no satellite being received signal. This fixed it.... Sky should be telling people this!:thumbsup:
