No satellite signal being received
Discussion in 'Satellite TV, Sky TV & FreeSat' started by IanMerseyside, Dec 26, 2006.
  1. IanMerseyside
    IanMerseyside
    I have been getting the above error message several times over the last few days but only on channels BBC1 and Bravo2 and once during a play-back on Sky+. There doesn't seem to be an actual problem with a lack of satellite signal as each time it has happened I have changed channel and got a picture immediately. Anyone had something similar?
  2. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    What readings do you get when you check the signal strength and picture quality?
  3. Goooner
    Goooner
    Jul 23, 2005
    38,881
    2
    Milton Keynes
    +17,498
    I'm getting it a lot just lately. I get the "no satellite...." message and if I go into services, signal test, I see either one or both of my feeds is "not locked". Normally this can be cured by reconecting the leads.
    I reckon I'll get Sky to come out and have a look, as it's happening too often for my liking.
  4. t256256
    t256256
    Oct 17, 2006
    83
    +6
    I've had this happen a couple of times in the past. Someone on the forum told me that this is a small 'bug' in Sky HD. Only solution is to power the box down, then back up. FYI: I get more channels going missing, but some (e.g. the movie channels), never seem to go MIA. Normally, it's BBC some of the UK channels and Bravo.
  5. Goooner
    Goooner
    Jul 23, 2005
    38,881
    2
    Milton Keynes
    +17,498
    When it was happening ot me, I was getting some channels, but not others (even with no signal on either feed), I was getting Living, but not Living 2 or getting UKGold but not UKGold 2 etc...
    Called Sky Weds, they said they'd send an engineer today (must say I was quite impressed, considering the time of year:) He duly turned up this morning, 8.30.
    Swapped the LNB on my dish and swapped the HD box for a brand new one, can't say fairer than that. I know we all have a moan about Sky at times, but that's pretty good srvice in my book. Only downside, I lost all my recordings, but I see BBC-HD are having a Planet Earth marathon on Sunday, so I'll be able to get most of it back:)
    Might be worth a call to Sky, if the problem persists, just make sure you've got nothing left to watch first:thumbsup:
