no satellite signal being received
Discussion in 'Satellite TV, Sky TV & FreeSat' started by MR ETOME, Jul 30, 2005.
  1. MR ETOME
    MR ETOME
    Nov 11, 2004
    110
    +8
    Have been getting the no signal message on and off for the past week but since yesterday I'm receiving no channels at all, just a constant no signal message.
    Looking at the settings menu, The signal strength seems normal, but signal quality is zero and there is no lock.
    I have a sky+ hooked up to the same dish, and this is working fine.
    So, is this a problem with The LNB or the box itself, the alignment of the dish is obviously OK as the sky+ box is working fine. :lease:
    Is there a service menu that I can go into to check if there is aproblem with the LNB?
    Many thanks in advance.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Unhook one of the Sky+ outputs and plug it into the suspect box. That will prove whether it's an LNB fault.
  3. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
