No satellite signal being received
Discussion in 'Satellite TV, Sky TV & FreeSat' started by the_sanguine, Dec 21, 2004.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    Ever since my system was fitted I've had this trouble. It used to happen only every couple of monthes. Sometimes it's worse that others but I was really ******ed off when I missed the champions leage Final as it happened out of hours.
    The last week, this has been happening at least once a day. What can I do?
    Is it just me or is everybody having problems?
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    unplug sat box from mains for 2 mins
    plug it back in and all should work.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Could literally be anything. LNB's odds on though. ;)
    Digibox make & model?
    A. Dork
  4. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    pj, I do that regularly.
    It's a Grundig I think?
  5. pezzer
    pezzer
    Jun 9, 2004
    185
    West Sussex
    I've had the same problem with my replacement sky+ box and second digibox - Sky Engineer coming out tomorrow to replace the LNB - when the satellite signal starts to go I notice that the 'transport stream' in the 'signal test' window starts to change its 4 character code - should be something like o7d4 but it changes and then I lose the sigal.
    I'll let you know if the new LNB sorts out the problem.
  6. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I'm wondering whether to write and complain to them. Maybe they will let me upgrade to Sk+ for £99?
  7. pezzer
    pezzer
    Jun 9, 2004
    185
    West Sussex
    Never hurts to ask !
  8. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    07d4 is, I guess, the PID in hex, equivalent to 2004 decimal.
    It looks like you have continuity errors in the received TS (Transport Stream) packets . A faulty LNB is certainly a possible cause of this, either due to it being noisy or its local oscillator drifting too much (poor stability / phase noise). A misaligned dish would cause the same effect.
    Chris Muriel, Manchester.
  9. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,247
    +670
    Ive just got this message on screen to and no amount of unplugging etc will fix it.Guess its the LNB as its the original since sky digital started.The engineers coming out weds but are you charged for this ?
    If there is a charge i may as well buy a quad lnb and fit it myself.
  10. 123orth
    123orth
    Nov 29, 2003
    263
    leeds
    i have started to get same problem since this morning
    sky box is panasonic
    rang sky technical service was guided thru to check the signal
    transport no has gone to 0000
    been offered engineer at 65£
    any solutions welcome
  11. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    Panasonic digiboxes aren't usually the cause of this problem.
    If all your connections are OK and the LNB power supply hasn't been turned off (installer menu - services-4-01select), then it'll be the LNB.
    Cambridge at a guess. :cool:
    A. Dork
  12. 123orth
    123orth
    Nov 29, 2003
    263
    leeds
    thanks arthur
    whole thing started after i changed the telly this morning cant think how the lnb's power could be off is there a way to check
    while i was on phone to sky today it actually cam back to some nos in the transport column but disappeared soon after
  13. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    Yes Cambridge or the cable is rotted where you screw it into the LNB. This will show up as No Sat Signal.
    This has happend to me 4 times :eek: My Cable ended up so short Sky fitted a new one :laugh:
  14. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    Could it be Rats in the Loft?
  15. PrinceAlbert
    PrinceAlbert
    Dec 19, 2003
    I was having a similar problem to this but i have noticed that i loose my satellite signal when someone with a T-Mobile or Orange phone goes near my Sky+ Box (if the phone is receiving a call/text or sending call/text). Has anyone else noticed this or is it to do with my LoftBox where the Interference is coming from ? The wires in the wall that go around my house through the loftbox are the proper Sky cables that is used during the installation (my mate used to install Sky and he gave me a roll).
    Any ideas ?
    Wayne
  16. Twoblock
    Twoblock
    I have an odd selective version of this, where the "no signal" error only apears on 5 channels - 5 music channels to be precise - Chart Show, The Vault, Scuzz, The Amp and Flaunt - and whilst I rarely view any of them, it is annoying that they don't work when all the rest of my channels work just fine - any ideas as to why this is?
