No room to fit Ps2 - Xbox - Amp - gamecube - DVD recorder
Discussion in 'Televisions' started by jamieuk23, Dec 31, 2004.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    HI I am considering buying 1 of these rear projection TVs but after doing a search on pricerunner.co.uk all the rear projection TV come on what seems is a large stand with a built in speaker below the TV, and there doesnt seem to be gaps or room to fit my
    AMP
    PS2
    xbox
    gamecube
    satellite
    VCR
    DVD recorder.
    Can you not just buy the screen on its own and then fit it to a glass table with loads of room for all the stuff mentioned above ??
  2. akan7
    akan7
    Dec 11, 2002
    319
    28
    England
    +67
  3. Muffminer
    Muffminer
    Nov 20, 2004
    301
    Hinckley
    +10
    If your after a normal rptv then id just consider getting a glass stand alongside the tv which would house all the equipment.
    If you're referring to DLP rptv then some come with a stand (some have to be bought as an extra) which allows you to house the av equipment.
