No RGB enabled cable with a new 360?
Discussion in 'Xbox Forums' started by Droogie 2001, Mar 24, 2006.
  1. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,486
    Surrey
    +113
    I am correct in saying that you do not get a RGB enabled cable with a new 360 or does it come with on in Premium version?
    Had to buy an ‘Advanced’ SCART with my Xbox surely RGB SCARTS are hardly advanced anymore?! :(
  2. drevil2nd
    drevil2nd
    Dec 2, 2005
    180
    +5
    no you get a hdtv cable with the premium and crappy composite with the core, a bit of cheek really.
  3. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,486
    Surrey
    +113
    Thanks. But you do get a crappy composite with the Premium as well?
    I don't suppose there is the slightest chance that the Xbox advanced works with the 360 does it?!
  4. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,148
    Bristol
    +9,893
    The Premium Pack comes with a cable with both component/composite connections on it.
    Also you cant use original XBox audio cables due to the connection being different so afraid you will have to buy the 360 RGB Cable but it is well worth the money.
  5. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    You don't get an RGB scart with either the core or standard version, no. You get a composite lead with both versions, but the standard version comes with a component cable too. All done to keep the cost down as many buying the standard version won't be using scart I guess.
