No Red Image Display on Proxima projector
Discussion in 'Projectors, Screens & Video Processors' started by gtec, Jan 27, 2005.
  1. gtec
    gtec
    I have a Proxima 6850 projector. It has recently quit displaying the color "red". (It displays the color "red" as black or dark gray. The other colors, blue and green, display fine. I have use the menu to adjust everything. I have also used different VGA cable with the same result. Why will the color "red" not display?
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,465
    Surrey. UK.
    +2,115
    Does it do it on all inputs? Are you sure it's not the source?
    Try another player via another input if you can.
    Gary.
  3. gtec
    gtec
    Gary
    When I connected another notebook, using the same VGA cable, to my LCD projector, as you suggested, the red image display returned. So, my problem is with my VGA connect on my notebook computer. (Red images display in PowerPoint on my notebook screen, but will not display using my LCD projector when I connect with the VGA cable.)
    Booker
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,465
    Surrey. UK.
    +2,115
    Glad it wasn't anything expensive. :)
    Gary.
