No Red and limited white
Discussion in 'Projectors, Screens & Video Processors' started by rickfike326, Jul 7, 2005.
  1. rickfike326
    rickfike326
    The Projector is a Sharp (not sure of the model #, it's at my church, I will get it tonight.) The problem is, I am getting no red, and very little white to display. The problem is not in the projector, because the menu displays both colors perfectly. Any suggestions on what it may be?? I'm stumped. Any help is appreciated. Thank you!
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,420
    Surrey. UK.
    +2,086
    What input are you using? Component, s-video etc and is your source a DVD player?
    Gary.
  3. rickfike326
    rickfike326
    HP computer on a dual monitor setting. It worked perfectly before, then suddenly I lost the colors a couple months ago.
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,420
    Surrey. UK.
    +2,086
    can you swap the connections over (assuming they're OK on the other monitor) or try a different input on the projector (a dvd player for example).
    Gary.
