No rears. Does it make much of a difference?
Discussion in 'Home Cinema Speakers' started by steve 111, Sep 28, 2003.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    I have a set of the old Kef Eggs, but the wife has refused to let me site the two rears until we move house next year. In the meantime I have to do with the 3 fronts plus sub.
    Am I missing out on much by not having the two rears, and is there anything I can do to create some sort of 5.1 experience with what I have got?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You are missing out on surround sound. It isn't just the special effects that are heard through the rear speakers but they are also used to widen and draw out the soundfield.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    erm yes you are i would drop the centre and run stereo or you will miss out on too much! Trade in the wife I say!
  4. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Why will dropping the centre channel make a difference?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    if you run stereo the you get all sounds through FR & FL if you run 5.1 Through 3 fronts and sub you lose the rear effects, and spacial sounds are lost so you have a very wide but flat sound field. It depends on the room but no rears really makes 5.1 rather a waste of time! If you can set the amp to no rears and run it all through the front 3 it could be ok but try it out and see what you find sounds better.
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    You NEED the rears - try to come to some arrangement.
    I would hate to have no rear sound
