no radio channels found
Discussion in 'Satellite TV, Sky TV & FreeSat' started by sirteuk, May 18, 2005.
  1. sirteuk
    sirteuk
    Nov 26, 2004
    281
    Cleveland
    +32
    Just recieved a SONY,VTX-D800U,installed with in loft aerial,on auto tune,found 60 channels,but no radio channels.
    I bought the sony on its reputation on reception in areas of weakness.ITV channels are breaking up .
    Is this due to in loft aerial only
    Mant Thanks Ian
  2. JayCee
    JayCee
    Jan 20, 2004
    21,742
    Lanarkshire
    +2,232
    More than likely, sounds as though you have a weak signal.
    You should ideally have a wideband aerial mounted outside for best reception as some modern internal roofing panels contain a thin mettalic sheet for heat insulation which attenuates the signal greatly.
  3. G-man.au
    G-man.au
    So what happens when you press the radio/ TV button? Does it switch into radio mode and just have no listings?
