No radiators heating. What can I check?
Discussion in 'Domestic White Goods Forum' started by 7ofnine, Feb 15, 2014.
  1. 7ofnine
    7ofnine
    Mar 31, 2009
    3,303
    +438
    Today we seem to have a problem with our central heating - none of the rads are heating up. I've checked the boiler, and it's firing up. Also checked the circulation pump, and it appears to be working. The pipes are hot coming out of the cylinder. Could it be a valve problem? Any ideas what I can check?
    It's a conventional boiler, not combi.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Could well be a 3-port valve in which the little motor/actuator needs replacing.
    There are threads monitored by heating experts in the General Chat section of these forums.
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,147
    +7,094
    As a 'get by' these 3 way valves usually have a manual control lever so that in the event of failure it can be placed into the mid position so that heating and hot water can still be had until it can be fixed.
  4. 7ofnine
    7ofnine
    Mar 31, 2009
    3,303
    +438
    Thanks guys. I checked the actuator and it was working fine. But when I took it off the valve to expose the spindle I just couldn't shift it. Bit of WD40, and now working smoothly. Problem solved!
