No power - troubleshooting in brief???
Discussion in 'Desktop & Laptop Computers Forum' started by uaeast, Feb 21, 2013.
  1. uaeast
    uaeast
    Sep 16, 2007
    34
    Hi all,
    Just acquired a zoo storm desktop which I know has a 1tb hard drive and 8gb ram, I got it for free and know it has something wrong with it but I don't know what.
    Just set it up (leads) but no power whatsoever comes on....
    How do I check the psu?
    Could it be anything else other than the psu?
    Thanks in advance!
    Joshua.
  2. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    Plug fuse.
    Is the fan in the psu running?
    Do you have access to a multimeter?
    Turn off the psu, unplug the psu from the motherboard, use a paperclip to short together pins 15 and 16 (green and black wires, do it from the back), turn on the psu. Does the fan come on?
    No fan: dead psu probably.
  3. Ari33
    Ari33
    Jan 22, 2009
    1,056
    +241
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    25,415
    Poole
    +10,415
    If there is a standby power LED on the motherboard check that comes on as soon as the mains to the PSU is switched on. Not as good as a PSU checker but quick and easy.
  5. uaeast
    uaeast
    Sep 16, 2007
    34
    Thanks for the really quick replys guys.
    I managed to get that problem sorted.
    The computer randomly blue screens.
    Error code 0x00000024
    Something to do with hard drive?
  6. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    For the benifit of others, the problem was.............................?
  7. uaeast
    uaeast
    Sep 16, 2007
    34
    Ermmmm :blush:
    I plugged it into an extension lead, assuming the socket on the wall was switched on, after lots of confusion I managed to look at the wall? :-(
  8. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    Thanks for the honesty!:laugh::laugh::laugh::blush::blush::(:(:(:
