No Pj Remote - Learning Remote Work?
Discussion in 'Projectors, Screens & Video Processors' started by Goof, Feb 16, 2003.
  1. Goof
    Goof
    Oct 14, 2002
    760
    Scotland
    I've been offered a Pj that I'm quite interested in, however, it doesn't have the remote. I can't seem to track down anywhere that do spares (but was thinking they'd be expensive even if I did!).
    Would a basic learning remote from Argos work even though I don't have the original remote?
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    It depends, what PJ is it?
  3. Goof
    Goof
    Oct 14, 2002
    760
    Scotland
    A Philips (can't remember model off-hand)...
  4. magking
    magking
    Jan 6, 2001
    378
    Norway
    If it's not a very old model i'm sure Philips will be able to get you a replasement.
    Problem with a learning remote is that you need the original to learn from. With a Philips Pronto remote you can download the software from the net, that migh be a solution.
  5. Goof
    Goof
    Oct 14, 2002
    760
    Scotland
    Thanks Mag, thought that might be the case but also thought it may even be able to learn from the Pj's own infra-red receiver. Not sure about the Pronto tho, call me nuts but I don't want to pay £70 for a remote! ;)
  6. PFM
    PFM
    Sep 24, 2000
    451
    Barton Upon Humber
    +17
    Hi folks,
    Checkout remotecentral.com, they archive a sh*t load of files for all types of learning remotes & hardware devices (inc PJ's).
    You may find your model if you search there.
    Hope this saves you a few quid:cool:
  7. Goof
    Goof
    Oct 14, 2002
    760
    Scotland
    Thanks PFM, will check it out :)
