baccattack
I hope there's someone out there who can help with this problem.
I took delivery of my Panasonic DMR-E30 yesterday and spent most of the afternoon setting it up and rejigging my existing kit. Anyway when it finally came to testing out it's capabilities I hit a problem. If I make a timmer recording from my ex ITV Digital Philips set top box, model DTX6370, setting the timmer on the box and putting the recorder in Ext Link mode ready to start recording when the set top box switches itself on I don't get any picture if recording in RGB. The sound is fine. If I already have the set top box on and I press Ext Link on the recorder it will start recording the current channel I'm on fine, in RGB. I also tested with setting my set top box to output composite from AV1 and on the recorder to accept composite on AV2, doing this gave no problems with timer recordings, picture and sound both present and correct. It seems my problem is confined to RGB timer recordings. When the recorder is in standby it passes through the RGB signal from my set top box fine.
My equipment is set up as follows. Philips set top box set to output RGB from AV1. AV1 from Philips going via scart to AV2 on Panasonic recorder. AV2 on recorder set to accept RGB and set up as Ext Link 2. AV1 on recorder set to output RGB via scart to TV's AV1 socket. TV is a Panasonic Tau TX 32PK2. All the scart leads are of the fully wired variety. I have also tried setting the AV2 on the recorder to Ext Link 1 but doing this meant it didn't switch itself on and start recording when my set top box came on.
I would be grateful if anyone could provide any suggestions. There must be others out there making timed RGB recordings from a DTT set top box. My parents have a Pioneer DTT box in the lounge which I got them so I'll try it with that tonight in place of my Philips, I also have a Pace FTA adaptor which is currently boxed up which I could try, if they have had the software download yet to provide timer recording facilities.
stephen
stephen
