no picture from component
Discussion in 'Plasma TVs' started by urbanlegend, Jan 31, 2005.
  1. urbanlegend
    urbanlegend
    Jan 14, 2005
    169
    +3
    just got my hitachi 5200 and i cant get my dvd surround system to give a picture?i have it connected component > component to av1.please has anyone got any ideas why i have no picture?just get the no sync signal
  2. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    Make sure you've got the DVD player set to output YUV from component rather than RGB (at least that's what I had to do on my 5300).
    HTH
    John
  3. Symey
    Symey
    what dvd surround? denon? if so component is not turned on by default - connect a yelloe rca vid cable and get into the dvd setup menu and turn output from default svhs to component..
    worked for me in the same situation mate
    if not denon - you may have similar ooption..
    hope thats of some help
    regs
    sy
  4. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    You are selecting the right av1 signal, with some tvs you have to scroll through to find the right input - usually it is automatic.
