No pic via component
Discussion in 'Nintendo Wii-U & 3DS' started by andyjenkins, May 2, 2007.
  1. andyjenkins
    andyjenkins
    Jul 4, 2003
    485
    28
    +44
    Hi guys,
    Throught I'd ping the Wii folk as well on this one .. just incase I'm doing something silly.
    New Wii turned up this morning. Via Composit - everything works. In TV Mode I can only pick the top two options - 50 & 60hz.
    Popped into Comet and picked up a Wii Component cable. Plugged it into my Tosh 37WLT68, changed to what I believe is the extention for the component - but nothing. Just a blank screen.
    Turned the wii off, restarted etc etc - but nothing.
    Do I have to somehow enable component as the output of the Wii???
  2. smooth750
    smooth750
    Jan 17, 2006
    35
    Have you changed your Wii settings from Standard TV (480i) to EDTV/HDTV to view 480p ? The option is somewhere among the wii setting menu>
  3. andyjenkins
    andyjenkins
    Jul 4, 2003
    485
    28
    +44
    Bah - TV specific error in the end. I had the composit cables still plugged in which overrides component signal.
    Problem solved.
