Quantcast
Question No output from my Denon Amp
LeoK77
Please Help!
I had been using my home cinema set-up at the weekend, went to watch a film in the week and now I am not receiving a picture through my projector. It says there is no input on the screen! When I plug the projected directly into Sky or Xbox I get a picture, as soon as I go through the receiver the picture goes!
please help!
dante01
TRy a different cable, especially if the one you are using is longer than 6m in length. If longer than this then I'd suggest using HDBaseT if dealing with 1080p HD video or even HDMI over fibre if wanting to convey UHD video.
Just because you get a signal if not going via the AV receiver is no indication of the cables you have being suitable.
LeoK77
Thanks for the reply. The cable had been working fine. It’s a High Speed HDMItm cable with Ethernet
dante01
Can you check the signal from the AV receiver using both the same cable to a different display as well as using a different cable to another display?
