No Optical Input on my Home Cinema Amp. Can I get Dolby 5.1 any other way ?
Discussion in 'Cables & Switches' started by Richy1968, Aug 3, 2006.
  1. Richy1968
    Richy1968
    Wondered if anyone out there has the Panasonic SC-HT500 connected to a Sky +/HD box to receive 5.1 sound?
    The box has an optical out and the Pana amp only has SCART and Phono inputs.
    Maplins do an Optical to Phono convertor : (http://www.maplin.co.uk/Module.aspx?...rce=14&doy=3m8)
    but I am not sure if the phono inputs or SCART on the receiver will process the digital 5.1 signal ?
    Anyone tried it, or know of any other way to acheive 5.1 from an external source on this home theater system ?
    Rich.
  2. davepuma
    davepuma
    Jun 24, 2004
    17,543
    +3,512
    You can only get 5.1 or DTS via a digital input i.e. optical or digi co-ax. I can't find any details on your amp but if as you say, it only has phono inputs (red/white) then you will only get Dolby Pro Logic at best (2.0 channel mixed to give surround sound).
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    This Home Theatre System boasts a Dolby Digital Decoder with DTS, but unfortunately there doesn't seem to be any way of connecting any external devices to it, so no DD5.1 from Sky, I'm afraid.
