No One Lives Forever Help Wanted.
Discussion in 'PC Gaming & Rigs' started by Garrett, May 26, 2004.
  1. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    The best thief you'll never see.
    +7,989
    I have got to a point where I need to use the cutting torch in the lighter, but when I bring it up in the inventory and click to use it I only get the lighter icon and not the cutting torch. Is there something I have to toggle to get it to work?
  2. finlab
    finlab
    Jul 23, 2002
    118
    Aberdeen
    Yes, but it's been a while since I played it. Just try the keys it's there somewhere or go to options control and see if you can change it.
  3. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    +7,989
    Thanks for the help.
    I have looked through all the keys and control for the keys and could not find a key to toggle the lighter to a cutting torch, but I will try again.
    I started the level again and it said on the default weaponry it was there, but I never found it.
    I will see if there is a patch as it may be a bug.
  4. finlab
    finlab
    Jul 23, 2002
    118
    Aberdeen
    Found this on a nolf forum as somebody had posted your question
    do you know how to change your type of bullets? press the same button while youve got your sunglasses on or lighter in your hand. thats alll there is to it
  5. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    +7,989
    Thanks finlab
    Found it you have to press the LH Ctrl key to toggle the multi equipment uses. RH will not work.
  6. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    +7,989
    Managed to finish it last night.
    finlab did you play the Game of the Year version?
  7. finlab
    finlab
    Jul 23, 2002
    118
    Aberdeen
    Yes enjoyed it and finished it
  8. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    +7,989
    Did you get the last mission with the monkeys.
    Must say at first I was not likening the game but as it progressed and especial after the pain was wasted I really enjoyed the game, lots of fun and loads of references to spy films and locations.
  9. finlab
    finlab
    Jul 23, 2002
    118
    Aberdeen
    Yep eventually caught the monkey. Iirc the ending was quite abrupt. Have never bothered to play nolf 2.
  10. Hawklord
    Hawklord
    Feb 15, 2003
    3,570
    4
    Aldershot, Hampshire
    +313
    It's very good if you can get your hands on a copy. Much like the first (same humour & gadgets etc) only a much better graphics engine. I thhoroughly recomend it:)
  11. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    +7,989
    Though of getting NOLF 2 in the 3 for £20 range may be as I belive Civ 3 is coming out for £10 in a bit.
    The ending was sort of abrupt, but think it was just an bonus level, as things were wound up on the previous mission. I liked the joke about the monkey but not mentioning what she said as it would spoil it for anyone who is going to play it.
  12. Hawklord
    Hawklord
    Feb 15, 2003
    3,570
    4
    +313
    I would give you my copy if I had it but I gave it to smurfin along with MOAA :D
  13. Rasczak
    Rasczak
    Apr 3, 2002
    22,034
    Warwick
    +2,897
    On a related issue PC Format mention that a No One Lives Forever 3 is being released this year.
