No On Screen Display on KAVC-A1SE
Discussion in 'AV Receivers & Amplifiers' started by NeilH, Jul 12, 2003.
  1. NeilH
    NeilH
    Aug 17, 2002
    248
    +3
    For some reason my amp doesn't seem to want to display the on screen display menus anymore.
    I'm trying to output, via s-video, onto my TV to allow me to tweak some settings.
    Cable in, TV set to accept s-video then...............nothing.
    Any ideas?
    Neil.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You normally need to have an s-video feed in to activate the s-video monitor output. Do you have this?
  3. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,461
    United Kingdom
    +1,915
    Have you got the Video set to ON? Also make sure the S-Video cable is plugged into MONITOR OUTPUT 1.
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    My telly will only display the s-vid feed when one of the scarts is also activated. I have to power-on my Sky box or VCR after I connect up the amp and then the on-screen menus appear.
  5. matrix_sid
    matrix_sid
    May 27, 2007
    13
    4
    I'm hoping someone had the answer to this problem coz I seem to have the exact same problem. I have tried both the S-Video and Composite Monitor outputs to get an on screen menu however I have read in other forums that it may be that the on screen menu has been switched off however the manual does not say how to switch it back on.
    I dont have a manual for it but would like to know if someone could help switch the on screen menu back on. I have reset by holding 6.1/7.1 Surround and Direct buttons together while powering up the amp and the display blinked with all the lights however this has not brought the menu back onto the screen.
    Any help would be much appreciated.
    Kind Regards
    Sid
  6. Jules
    Jules
    Oct 11, 2000
    5,584
    134
    +1,045
    The most likely reason is as Jase has said, that you have connected to Monitor 2 by mistake.
    Only monitor 1 carries the OSD.
    If you are getting the source picture via the amp then I can't see it being anything else as there's no way to turn off the OSD other than by turning of the video circuits altogether.
    If you are simply using the S-Video for OSD only (connecting your sources directly to the TV) then check the following.
    1) You havn't pressed the 'video off' button by mistake.
    2) You are not in Pure Direct mode.
    3) Your S-video cable isn't damaged or wired in the opposite direction.
    Remember that if its an S-video > Scart cable it must be wired in that direction. A Scart to S-Video cable won't work.
