No. of scart (RGB) connection on the back of a Sky+ box?
Discussion in 'Sky Digital TV Forum' started by Justhe1, Sep 9, 2004.
  1. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    I am due to have sky+ installed in the next few days, and currently have sky digital.
    I am just trying to figure out how to connect my PS2 to my plasma (without buying additional terminal boards) and wondered if the sky+ box had a spare scart (RGB) input that I could run my PS2 into via a PS2 to RGB scart (hopefully this could carry a component signal?)
    My (to be) sky+ box could then plug into my JS converter box to plasma.
    Just trying to see if I can do without the Quintro box and save a few pounds or not??
    failing that I could go directly from PS2 to the scart board in the plasma, just means a "messy" long lead running up to the screen.
    Any help much appreciated
    J
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Sky+ will pass RGB when in standby, not sure while its recording but would hope so, connect PS2 to VCR scart on Sky or Sky+ box and use same scart on TV for both.
  3. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Ah great, I wasn't sure if the VCR scart was output only, but I take it it switches then to receive the input from the PS2.
    Had it mentioned to me as an option by a friend/installer but was unsure it could be done.
    Will save me the Quintro Unit + 1 scart and/or running the PS2 directly to the screen...
  4. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi J
    thats correct, when the PS2 is powered it will override the RGB feed from the Sky box so you will get a switching effect.
    good luck
  5. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Great, thats just saved me a Quintro + 1 scart cable, cheers guys :)
