no midrange or bass at all from surrounds
Discussion in 'Home Cinema Speakers' started by mick23, Aug 13, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    playing music 5 chan sterio ,the 2 s/round speakers treble only nothing from mid/bass drivers at all, checked cables etc ,nothing wrong, tried another amp, with just the surrounds main drivers not working, any advise please, i thought if you had bother it would be tweeters that fail,
  2. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Might be a stupid question but could it be caused by rear speakers being set to "small" on amp?? Try setting to large if they are and see if that makes a difference...
    Sorry I can't be of anymore help - hope you get it sorted.
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    tried with old 2channel sterio amp ,still the same,(blown crossovers etc?)
  4. Bapapapa
    Bapapapa
    Jul 24, 2000
    113
    16
    Apologies if I'm teaching you to suck eggs, but are the connecting plates between the hi/low freq. speaker terminals in place..?
    :clown:
  5. sofaboy
    sofaboy
    what amp are you using? is it Yamaha?, if it is i might be able to help
  6. mick23
    mick23
    Mar 20, 2002
    801
    uk
    amp is 3802
  7. dAvE6
    dAvE6
    I used to own that amp. I found it gave quite a thin aound anyway. To all channels.
  8. john87
    john87
    That would be no bass. Mid-range would still be produced.
