No menu sound on Terminator 1 SE
Discussion in 'Blu-ray & DVD Players & Recorders' started by Russ, Mar 25, 2001.
  1. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    Strange lack of sound during the menu on T1 SE ! The lion roars but then there is no sound on the menu until I play the movie.
    I output the audio from my Wharfedale 750s throgh coax to a Sony 930 amp. The video goes from the DVD through an RGB only Scart.
    The Amp senses PCM from the dvd player during the menu but there is no signal.
    I can get a signal through the normal audio outputs but this defeats the point of the coax connection. CDs etc play fine.
    Any ideas anyone ?
  2. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    You "should" be getting sound during the menus - I will have a look when I get home to see what signal is being sent to the amp (I suspect it is DPL) My Pioneer 626 is connected to my Denon amp with a digital coax only if that means anything ... [​IMG]
    "Hi my names Paul and I'm a dvdaholic ..."
