No instructions for Blaupunkt Lausanne CD30
T
TommyRed
I've inherited my late Fathers car to sell for my mother. We eventually found the handbook but can't find any instructions for the CD/stereo. The problem is only the back 2 speakers work and no-one is really sure if there is a fault on the front 2 or if it's a setting on the CD player. Any ideas? or where I could download a manual from? TIA TR
lynx
Senior Moderator
Press the audio button on the front panel, that should show a menu with two options, one marked balance the other fader - fade to front should solve the problem.
T
TommyRed
Just tried that, the fader menu is on a button called GEO, AUDIO just brings up bass, treble and the track number etc of a CD playing. The fader on GEO goes from + to - 9 which still doesn't bring the front speakers in, could this be a wiring problem? TR
lynx
Senior Moderator
Look and see if speakers are actually present in the front doors.
T
TommyRed
Yes, checked there do appear to be speakers there. Also noticed that part of the carpet is loose under the console which houses the CD player, there is a connector hanging there but could be for anything, can't locate the other part if somethings come loose. The loose carpet might indicate a previous problem. I'd take the unit out and check if I knew how. TR
lynx
Senior Moderator
Very easy, pick up a removal tool from an accessory shop (similar to the image below)
T
TommyRed
Sorry haven't been here for a while the Wifes got me decorating. Thanks for info, didn't realise you could buy a removal tool. Due to car break-ins I thought only car radio people would have them. TRl
